05-24-2006 11:10 AM
05-25-2006 02:23 AM
Hi Nick,
we have several applications that use to run for several months and never had suffered a problem like yours. It is to be said that we usually don't minimize the main panel but one of those applications can be "minimize" by the user: the main panel is actually minimized but a small window remains left on the screen holding some informations on the test processing: a button on that secondary window restores the main panel. You could try something similar, i.e. not relying on system menu commands to restore your application but but using an explicit callback to restore the main panel of your application.
Just my 2c...
05-25-2006 07:55 AM
SetSystemAttribute(ATTR_TASKBAR_BUTTON_VISIBLE, FALSE);
2. I edited the main panel in the UIR so the option "Has Taskbar button" is enabled.
With these changes, the main panel will minimize to just a button. The only drawback is the program is no longer listed as an "Application" in the Windows Task Manager. It appears as a process though.
I did have one instance of this issue appear when the main UI was NOT minimized. In this case, the UI was displayed, but would not respond to keyboard or mouse events. The system menu did work and I was able to minimize the panel, and thereafter it could not be brought back.
We do have many of these applications running on older PCs that are running Windows NT 4. Do you think the OS may be an issue here?
04-15-2015 02:26 AM - edited 04-15-2015 02:35 AM
Even i am facing the same problem during the run time if i maximize for sometime again 'm not able to restore it back ..I tried the option Has task bar but no use
