10-28-2013 09:58 PM
Hello
The X axis I think in the display panel logQ base Q, but the X axis value or the logQ this calculated value, for example: the requirement that correspond to the 1000 in the log1000 X axis,. Would you please tell me how to do? As shown in Fig.
Thank you
10-29-2013 02:49 AM - edited 10-29-2013 02:51 AM
I'm not sure if I understood you correctly, but every single axis in a graph can have a log scale: you can set it this way:
The result is as follows:
If this is not your problem, can you rephrase your questio so that we can understood what you need?
10-29-2013 03:27 AM
Thank you very much for your reply
But I still can't solve. My question is this: I think, in the X axis of the Lable display LogQ value corresponding to the Q value, but the
actual scale of X axis value or (LogQ) to calculate
As shown in figure X axis is the Log1000 and Log5000 of 1000 and 5000;but the actual calibration of X axis value or (Log1000), and (Log5000) to calculate, just above the scale of Lable into (Log1000) and (Log5000) corresponding to the 1000 and 5000
10-29-2013 04:02 AM
That is: instead of printing "1000 1500 2000 5000" on the axis scale you want their logarithm (base10 logs: "3 3.17 3.30 3.7")?
May this be solved by using the Arbitrary axis lable feature of graphs? You can place your own labels on each graph axis: this feature is enabeld either in the UIR editor (see the Axis Label Strings box int he lower left corner of Edit Axis Settings window in my last message) or programmatically; in the latter case, you can look at samples\userint\timeaxis.cws example to understand how to populate the axis labels.
