03-28-2017 02:26 PM
I am using ListTypes in LabWindows/CVI 2015 15.0.0 (413). Windows 7
When attempting to use the ListPreAllocate() function I am seeing what appears to be an undocumented limit to the pre cache memory that can be allocated.
I understand the requirements of contiguous available space for [m][c][re]alloc to succeed, and I suspect the same is true for initial allocation using ListPreAllocate. So In the following code, I added a calloc statement to see if it would also fail. It did not. So, while I can allocate memory equivalent to 30 list items using malloc, the call to ListPreAllocate fails:
struct SCRIPT, has sizeof(SCRIPT) of approximately 8K.
char *buf = malloc(262080);//size equivalent to 30 * sizeof(SCRIPT)
if(!buf) return -1;
ListType list1;
list1 = ListCreate(sizeof(SCRIPT));
if(ListPreAllocate(list1, 30*sizeof(SCRIPT)) == 0) return -1;//fails here, whether or not the malloc call above is called.
I also observed that 25*sizeof(SCRIPT) was successful.
Is there a designed limit to the memory that can be allocated using this function?
Or some parameter that needs to be set?
03-31-2017 01:43 AM
Hello ryk,
The 2nd parameter of ListPreAllocate is "Num Of Items To Preallocate". If you want to allocate memory for 30 structs you should pass 30 and not 30*sizeof(SCRIPT) because the list already knows that the size of an element is sizeof(SCRIPT) from ListCreate call. If you use 30*sizeof(SCRIPT) it actually allocates 30*8K*8K
Constantin
