LabWindows/CVI
ListFindItem with StartingPosition out of range: BUG
The index returned by ListFindItem is WRONG when:
  • StartingPosition  = 0 ( this is a wrong value: StartingPosition must be >=1) .
  • The searched value equal to the LAST item inserted in the List:
The code example below shows the bug in the TEST_D:
int main (int argc, char *argv[])
	ssize_t 	startingPosition = 0;
	size_t 		index = 0;
	int 		val = 0;
	ListType myList = NULL;
	myList = ListCreate (sizeof(int));
	val = 1;
	ListInsertItem (myList, &val, END_OF_LIST);
	val = 2;
	val = 3;
	// TEST_A: OK
	startingPosition = 1;
	val = 1;
	index = ListFindItem (myList, &val, startingPosition, IntCompare);
	// index = 1 --> OK
	// TEST_B: OK
	startingPosition = 10; // WRONG value: startingPosition is over the number of items.
	val = 1;
	// index = 0 --> OK because startingPosition is out of range (>3)
	// TEST_C: OK
	startingPosition = 0; // WRONG value: startingPosition must be >= 1
	val = 1;
	// index = 0 --> OK because startingPosition is out of range (<1)
	// TEST_D: NOT OK
	val = 3;   // value of the LAST ITEM inserted in the List
	// index = 3 --> NOT OK: the behaviour is different compare to TEST_C.
	// In this case, ListFindItem must return 0 (NOT 3) because startingPosition is out of range (<1).
	// If you look for another item (not the last: val=1 ou val=2) ListFinfItem returns 0 --> OK
	return 0;
(4,305 Views)
Accepted by topic author jm73
Hello jm73,
The behavior you are seeing is expected. Please note, you can use the following two macros to specify starting position: END_OF_LIST and FRONT_OF_LIST. The macros are defined as follows in toolbox.h:
#define FRONT_OF_LIST -1 /* Handy Constants that substitute for item positions */
#define END_OF_LIST 0 /* END_OF_LIST means one past current length of list when
inserting. Otherwise it refers the last item in the list. */
By specifying 0, you are telling the ListFindItem function to start looking at the end of the list, which is why it finds the last item.
Daniel Dorroh
(4,291 Views)
The reason this is not a bug is because passing 0 to ListFindItem is actually not invalid. This happens to be the special value END_OF_LIST:
Given this, your results in TEST_C and TEST_D make sense.
Luis
(4,289 Views)
Darn, took too long...
(4,288 Views)
