LabWindows/CVI
Labwindows DLL in IIS 8 environment
I have user setting up a Labwindows DLL call in a Windows IIS 8 enviroment.  The process generates an exception when the DLL is called.  Anyone have experience with this environment?  Anything special that needs to be done? DLL is 32 bit.
Error reads: An attempt was made to load a program with an incorrect format. (Exception from HRESULT: 0x8007000B)
(4,452 Views)
You're not telling us which CVI version you are using... the supported OS are listed here
(4,448 Views)
V  13.0.1 (201)
(4,445 Views)
Hi ruskin1,
This error is commonly related to 32-bit / 64-bit compatibility, so I would suggest making sure that the application calling the DLL is also a 32-bit program.
Myriam
(4,392 Views)
