Hello
The CVI Run-time is fully backwards compatible, so you would have no problems using the CVI 5.5 development enviornment with the CVI 6.0 run-time.
It's always better to grab the newest driver software, mainly because it might contain not only newer functions, but fixes and speed improvements. However, if you are unsure, I could install it on a test machine and make sure everything works ( which it most probably will)
Bilal Durrani
NI
Bilal Durrani
NI
