11-01-2013 08:54 AM
Edna,
I was able to upgrade my IE.
I have my database set up through the data source tool on each machine where the application is running. I have never had issues with this method before.
I am attaching the file with my database interface.
11-04-2013 11:45 AM
Ok no problem. Let me know what happens.
12-04-2013 07:25 AM
Hi John,
I wanted to follow up with you and see if this issue was resolved. I am currently taking a look at the file you attached to see if there is any direction I can help provide.
12-05-2013 08:54 AM
Hi Evan,
I ended up rolling back the rev on the LabWindows to the latest 2012 version. I have not had time to investigate the problem with 2013 and my database. I am gettin a new PC while retaining my old development PC s I can keep 2012 on the old machine and loading 2013 on the new machine. This set up will give me more chance to investigate.
I pose a question though. My application builds with the SQL Toolkit version 1.1.1. Could that be an issue with 2013? It has not been through all prior LabWindows revs.
12-09-2013 05:03 AM
It is possible that the older version of SQL Toolkit could be part of the problem. I looked through the previous posts and could not find what OS you are running on. What version OS are you currently and what version had you been previously running?
