Hi, I need to swab bytes to handle BIG / LITTLE ENDIAN. Is in LabWindows something like void __cdecl swab(char *, char *, int); available (didn't find it yet) THX
No that I know of. But you can do it with either of the following two methods (assuming you are trying to convert Little Endian to Big Endian):
Method 1 - For Loop:
#include #include
main() {
short, int data[32]; int;
for (i = 0; i < 32; i++) { char temp; temp = (char) (data[i] & 0xFF00) >> 8); data[i] = (data[i] << 😎 & 0xFF00; data[i] = data [i] | temp; }
Method 2 - CVI's Scan function:
Scan (data, "%32i[b2] > %32i[b2o10]", data);
The number of bytes modifier [b2] modifier simply tells the Scan function that the data is short (2-byte int). The order modifier,[o10], tells the Scan function that the byte order is [10] or a descending order of precedence as compared to [01], which would be an ascending o rder of precedence.
