When I am working with a configuration controlled (via Visual Source Safe, or such), I always forget to change the READ-ONLY attribute. Then when I open the file under LabWindows/CVI, and try modifying the file, it wont let me do so, unless I get out of CVI, change the attribute, then re-open the file again.
- in Visual Studio, if the file is READ-ONLY, I can change the attribute (in a DOS window), and continue modifying the file as I need to. The IDE doesn't prevent me from doing so.
Is this feature being incorporated in version CVI IDE 7.0?
