Hello Babak,
I was unable to reproduce your problem. I had CVI 7.0 open with a complete project, including the .uir file, pulled up. I then browsed to another .uir file and double clicked on it. The file was opened in the current instance of CVI. No other instance was opened. The file was not automatically added to the current project, however. Is that what you are trying to do?
It looks like I might need more information on your current configuration in order to reproduce your situation.
If none of these suggestions help, or if I�m not correctly understanding your issue, please post the software and versions you are using, the applicable portions of your code, and any other information that may help, and I�ll be happy to look further into it.
Have a
nice day!
Robert M
Robert Mortensen
Software Engineer
