05-14-2010 12:39 PM
I have an application where I am using InetPing to verify a network exists before performing network centric tests. This has been working successfully, to the best of my knowledge for some time (months). However I was just running the test and observing the performance when I noticed the function returned a success when I could clearly see the network was not yet up. I removed the RF connection to ensure the network would not come up and the function is returning the network device is available about 1 in four of five attempts. What is going on with this function that would cause this sort of problem?
Thank you...
Solved! Go to Solution.
05-14-2010 03:50 PM
05-17-2010 09:10 AM
05-17-2010 09:18 AM
Hi Mohan,
I haven't found this issue in the 'LabWindows/CVI 2009 Known Issues' list (http://zone.ni.com/devzone/cda/tut/p/id/11438)...
05-17-2010 11:39 AM
Hey Wolfgang,
We have only just recently found out about this issue - too recently for me to have gotten it into the list. It will be there on my next revision.
NickB
05-17-2010 12:17 PM
Hi Nick,
Thanks! Let me add the suggestion to display the date of the last revision to the list. This way a visitor might see if there are new entries.
05-17-2010 01:16 PM
Hey Wolfgang -
It's already there - just down at the bottom and easy to miss...
NickB
05-17-2010 01:20 PM
01-09-2015 09:11 AM
Hello Mohan
I'm not able to find the ID of this bug and/or check if it has been fixed in some CVI release.
Could you provide this info, please?
01-12-2015 04:52 PM
Looking at this: http://www.ni.com/product-documentation/12156/en/
It seems to have been resolved with LabWindows/CVI 2009 SP1
