08-02-2008 11:44 AM
08-04-2008 09:17 AM
08-05-2008 10:15 AM
Hi Nate,
Your suggestion solved the problem finding the IMAQdx library. I am taking the machine vision application we previously discussed and trying to use it in Labwindows/CVI.
Thanks again,
Doug Dunlap
11-11-2011 01:48 PM
I'm having this problem as well; I downloaded and installed both the Vision Acquisition module 2010 and Vision Development module 2010 SP1 for my Labview Professional 2010 SP1, but the IMAQdx pallete does not show up, and programs that used the IMAQdx Grab.vi can not load that vi and other IMAQdx vi's. I tried your method above by going into the add/remove programs and adding the feature(you're right, it previously was not installed, there was an x next to the option) and installed it, but still, I can't find the IMAQdx pallette and the programs still cannot find them either. I do see an IMAQdx folder in my NI directory though, with a niimaqdx.lib file. Are there other files I still need? I'm lost as to what to do, please help!
06-27-2016 01:47 PM
Hi JWmit.
Could you solve the issue with the IMAQdx Library already?
I'm facing the same problem right now, and I will appreciate your comment on how you solved it.
Thanks in advanced.
06-28-2016 04:01 PM
Hi Pelesho,
You may have better luck posting a new topic so that you may get more visibility on your question. This post is 5 years old now so there is a small chance that someone will see your post. Check out point three of the NI Discussion Forums User Guidelines for more info.
03-03-2018 08:32 AM
I have selected LabWindows/CVI Support during installation but IMAQdx library is not visible.
Please suggest the solution.
Thank you.
03-05-2018 04:11 PM
Hello jasrajrajpurohit,
Do you happen to have screenshots of the installation window itself? Can you post the exact options you have selected and display them here for the group?
Also can you open your start menu, navigate to the National Instruments folder and find "Vision Documentation". If this exists then we have the vision software installed, but if not that means the installation didn't complete properly.
Please post this info back and we will be happy to help further!
