Hi Mark,
can you attach a snippet of the data - I'm assuming that if you can see the data itself, then you are able to get it back to CVI ok, and all you need to do is the graphing? What do you mean by collecting data - are you having a problem with the comms that stops CVI seeing the information? Have you tried (if it's a GPIB link) ibic, or the communicate with instrument section in MAX? Are you using serial comms or GPIB? What's the instrument - do you have a driver or are you sending the request for data command raw?
Once I've got a snapshot of the raw data, I can give an example of how to split it up and graph it.
You haven't said whether the data is comma separated, tab deliminated etc, and what format the data is in - floating point, engi
neering, integers etc.
S.
// it takes almost no time to rate an answer
