LabWindows/CVI
I want Example FM Receiver for RFSP on CVI ........ please.
I want Example FM Receiver for RFSP on CVI.
I can find only the FM Demodulation but I wan't to use it to FM Radio Station.
Cat LOL
(4,425 Views)
I am not aware of anything called, RFSP. Did you mean you are looking for a FM receiver example, in CVI, for the NI-RFSA drivers?
Matthew R.
Field Applications & Systems Engineer
(4,397 Views)
I'm looking for FM receiver example, in CVI
Thanks you
(4,359 Views)
I still do not know if you are trying to use the RFSA drivers or not. I assume you are, in which case, I was not able to find any examples, shipping or otherwise, for a FM receiver in CVI. What I was able to find was an example for LabVIEW, and a CVI shipping example for FM demodulation using NI RFSA. You should be able to figure out how to make a FM receiver in CVI using the combination of these resources. However, you may need some addtional toolkits for signal processing.
NI-RFSA: FM Radio Receiver in LabVIEW: https://decibel.ni.com/content/docs/DOC-30233
Assuming you have the NI Modulation Toolkit, with CVI support installed, the CVI shipping example for FM demodulation using NI RFSA can be found in the following directory:  C:\Users\Public\Documents\National Instruments\CVI\samples\amodt\for niRFSA\FMDemodulation.
Matthew R.
(4,343 Views)
