LabWindows/CVI
I can scan voltage using a DAQ card but I can I write a function that will continuously scan the channels I select until I wish to stop. i.e. A control that begins a scan and a control that stops a scan??
It seems that once a scan has begun the user has no control of the GUI until the scan is complete. Is it possible to create some sort of control button that will initialize a scan for an unspecified amount of time until a "stop" button is activated?
(2,652 Views)
See a related discussion as it develops here:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=506500000008000000EA950000&UCATEGORY_0=_318_&UCATEGORY_S=0
(2,652 Views)
npresnel,
You can also search our site for example programs, specifically ones written in CVI that do continuous data acquisition. Here's a specific one I found that may show what you want to do. http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3E79156A4E034080020E74861&p_node=DZ52302&p_source=external.
Good luck with your application!
(2,652 Views)
May i know how do u scan voltage using DAQ card?
What are the connections you made and also what is the program that you wrote?
Leroy
(2,652 Views)
