If you need to measure frequency you should use frequency or period measurement. Examples for these measurements are installed on your system together with DAQmx: open CVI and run Help >> Find examples... menu function. Navigate in the tree in the middle of the Example Finder window up to Hardware Input and Output >> DAQmx >> Counter Measurement >> Digital Frequency or >> Period or Pulse Width: there you'll finde some examples on the available solutions.
