Hello
In order to use this device, you would probably need a C driver of some sort, something the manufacturer would usually provide. If this device is programmible, you would get a driver with the card. Since CVI is an ANSI C compiler you would need to make sure that the api provided by the manufacture will work with a C compiler.
Bilal Durrani
NI
Bilal Durrani
NI
