11-27-2012 08:12 AM
Sorry for my english. I'm basically frenchspeaker. I hope I will use the good terms.
My question:
In LabWindows/CVI 2012, what is the "IVI" function which allows us to set the "FM rate" as well as the "FM Waveform" of the E4421B Signal Generator ????
11-28-2012 10:28 AM
when you expand the tab "RF" that is listed unter "Configuration" then you will find some
functions. One of them is agesg_ConfigureRF.
Then there is another function -> agesg_configureFM where you can specify your modulation source..?
At the path where you installed the drivers you can find a help document. -> agesg.chm
This document will provide you with lots of infos.
Are this infos helpful for you?
Or could you please discribe your problem with more details.
Thanks a lot.
Andreas K.
NI Germany
