10-25-2013 08:28 AM
I would like to send a big array (a picture in fact) to another computer via a TCP server.
I already use the TCP Support Library to send data to a software running on a different computer and it's working well.
So I did the same thing with a integer array and it doesn't work. I used the sample of Labwindows's help to send this array, and only the first part of the array is received.
I don't understand.
int SendImage(BYTE *lDataToWrite) { DWORD dwWaitResult; int bytesToWrite; int bytesWritten; int messageSize; if (giTCPConnected1 == TRUE) { bytesToWrite = messageSize = sizeof(BYTE)*WIDTH*HEIGHT; while (bytesToWrite > 0) { bytesWritten = ClientTCPWrite (giTcpConnection1, &lDataToWrite[messageSize - bytesToWrite], bytesToWrite, 0); bytesToWrite -= bytesWritten; } } return(ERROR_NO_ERROR); }
WORD Tab[WIDTH*HEIGHT]; ... ... SendImage(Tab);
int CVICALLBACK ReceiveTcpMsg(unsigned hdl, int event, int error, void *callbackData) { int iDataSize; int i,j; DWORD dwWaitResult; int bytesToRead; int bytesRead; switch (event) { case TCP_CONNECT: giTcpConnection = hdl; giLineConnected = TRUE; break; case TCP_DATAREADY: // Read tcp/ip data bytesToRead = messageSize = sizeof(WORD)*WIDTH*HEIGHT; while (bytesToRead > 0) { bytesRead = ClientTCPRead (giTcpConnection, &Tab2[messageSize - bytesToRead], bytesToRead, 0); bytesToRead -= bytesRead; } break; case TCP_DISCONNECT: giLineConnected = FALSE; break; } return (0); }
Is someone has already used these functions with a big data size ?
Or do you know other methods to send an array to an other software ?
Thank you for your help.
Benjamin
Solved! Go to Solution.
10-25-2013 10:42 AM
When I had to perform something similar to your task I have found more confortable to split the dispatch in several smaller pieces (say more or less 3-4k bytes each).
This gave me also the possibility to monitor ethe process and eventually to interrupt it.
10-30-2013 08:18 AM
Thank you for your answer.
I tried to split data in pieces of 3kB and it's seem working. I will finish to test it but it's in good way. Thank you.
Benjamin
