The GetUserBitmapFromText function is an undocumented function that is only used by that instrument driver. Its purpose is to load images in the type of format that is saved in .tui files (the "Options>>Save in Text Format" option in the UI Editor). We use this format in graphcursors.fp in order to avoid having to distribute all those icon files.
The function is not documented because you cannot, using the UI Library, programmatically save files in this format. Therefore there wouldn't be any ocasion in which you would this function. If you would like to do something similar in your own application you can: you'd have to use the UI Editor to save the images, and then you can use this function to load them.
Having said this, unless you have
a very good reason to use this ASCII format, you really should be doing what Bilal recommended. That is the supported, official way to save and load images.
Luis Gomes
NI
