05-22-2017 08:37 AM - edited 05-22-2017 08:38 AM
Hi everyone,
I'm a french student, working on Labwindows/CVI during my internship. I have a problem with Excel. Indeed, i found a way to save data from a table in CVI, i copy it to Excel (Data provides from a spectrum analyser R&S). However, if i want to save several data (631 points), in the end, i have only 1 column in Excel with the last measurement.
I would like to save the data in a new column everytime but i don't know how to do. Do I have to create a loop? if its the answer, I don't know quite well how to do this.
If someone can help me,
Matthieu
05-22-2017 10:28 AM
The Excel Report library may be useful to do this. Add the file excelreport.fp to your project and use the library functions to create a new Excel application (ExcelRpt_ApplicationNew), workbook (ExcelRpt_WorkbookNew), and worksheet (ExcelRpt_WorksheetNew). Then you can call ExcelRpt_WriteDataFromTableControl to copy the data from your CVI table to a cell range that you specify.
05-22-2017 12:48 PM
Thank you for your answer, but i already did that. The problem is that I would like to copy the data several time in differents columns.
I found out a way, I add a column "A" at every loop so my data are saved in the A column, loop, new column and the other data are saved in the new "A" column.
I don't know if i explain well my problem, but if there is a better way to solve it...
