09-30-2011 08:01 AM
Is there a way remove every bit of NI software from a computer?
The Windows uninstall application apparently leaves NI artifacts behind. Even though no NI software remains in the list of installed programs the next time I try to install NI software the NI installer recognizes that some pieces are already there. I get messages saying a newer version is already installed. Then the installation fails.
Will I have to reinstall the entire system to clean it up?
thanks
09-30-2011 09:27 AM - edited 09-30-2011 09:28 AM
The procedure to completely remove NI software from the system is described in this post.
09-30-2011 10:01 AM
Roberto,
I read the procedure. It's pretty complicated and hasn't been updated to address Windows 7 specifically.
Since I have a deep and abiding fear of the registry I may prefer to format the drive and start over. Even though it means reinstalling a ton of other stuff I don't want NI ghosts haunting me in the future.
Thanks for confirming my suspicion of how messy the process is.
PS: Shouldn't professional software clean up after itself? In most neighborhoods people are required to remove any poop their pet leaves on someone's lawn.
09-30-2011 11:20 AM
10-05-2011 11:12 AM
Roberto,
Thank you. You have helped me many times, always with well considered responses.
I tried the Windows Add/Remove Program utility as shown in the last link you provided. It doesn't seem to clean up all traces of NI software however. Subsequent installations seem to recognize that NI software has been installed previously.
david
