LabWindows/CVI
How to read the version number of a DLL?
does anybody has an example code on how to get the version of a DLL file? I know it should work with the GetFileVersionInfo(..) function, but I get project link errors, altough including "window.h"
Thanks!
Greg
(3,987 Views)
Accepted by topic author Greg_NTI
just found the solution in the SDK samples samples\sdk\verinfo\verinfo.cws". ...
(3,977 Views)
hello,
where is this location, is it in labview examples, unable to find it.
can you please post it
Thank you
(3,445 Views)
freemason,
Why are you looking around the cvi board? Do you want c code?
(3,436 Views)
Hello freemason,
This is the LabWindows/CVI board, which a C programming environment. If you are looking for LabVIEW help, I suggest posting to the LabVIEW board.
That being said, I did find this example for getting file version info for DLLs and executables: Community Example: Get File Version Info.
I also found this KnowledgeBase article about getting the version of an executable in LabVIEW.
Hope that helps,
Taylor B.
(3,419 Views)
Thanks for the help got it
(3,395 Views)
