LabWindows/CVI
How to make an array with ActiveX Excel using Excel_RangeSetValue2?
I want to make an array on Excel. For that, I'm using two functions : Excel_WorksheetGetRange and Excel_RangeSetValue2.
I write the array on Excel file but only the first case of the array is copied.
Here, a part of my program :
char * DataToWrite = {"A", "B", "C", "D"}
char cCell[10];
VARIANT             vCell, Data;
ExcelObj_Worksheet hWorksheet;
ExcelObj_Range      hRange;
  CA_VariantSetCString (&vCell,cCell);        //cCell = A1:A4
  Excel_WorksheetGetRange (hWorksheet, NULL, vCell, CA_DEFAULT_VAL, &hRange);
  CA_VariantSetCString (&Data,DataToWrite );
  Excel_RangeSetValue2 (hRange, NULL, Data);
Here what I obtain when I'm compiling on Excel file :
A
A
A
A
(4,444 Views)
Accepted by topic author Toto555555
You should use other instructions to fill the range of cells:
strcpy (msg, "A1:A4");
CA_VariantSetCString (&MyVariant, msg);
Excel_WorksheetRange (ExcelWorksheetHandle, NULL, MyVariant, CA_DEFAULT_VAL, &ExcelRangeHandle);
Excel_RangeActivate (ExcelRangeHandle, NULL, NULL);
// Create a SafeArray from array of data CA_VariantSet2DArray (&MyVariant, CAVT_CSTRING, righe, 1, array); // Transfer data to Excel range Excel_SetProperty (ExcelRangeHandle, NULL, Excel_RangeValue2, CAVT_VARIANT, MyVariant);
ClearObjHandle (ExcelRangeHandle);
(4,426 Views)
Thank you for your solution, it works. It helps me to find one with another functions :
  char            strCell[10];
  VARIANT             vCell,vData;
  CA_VariantSetCString (&vCell, strCell);
  Excel_RangeActivate (hRange, NULL, NULL);
  CA_VariantSet2DArray (&vData, CAVT_CSTRING, iNbElts, 1, strDataToWrite);
  Excel_RangeSetValue2 (hRange, NULL, vData);
  CA_DiscardObjHandle (hRange);
(4,420 Views)
