03-05-2017 04:27 AM
I have a project on uploading two diffrent audio files, and combining them together.
Is there a way to upload the wav file as an array on CVI?
Second, I would like to active the mix file on the UIR, is there a way to play the record on some kind of a media player? or anything on active X on CVI?.
Thanks for your help!
03-06-2017 03:12 AM
With reference to your second question, an external resource like a media player or an ActiveX control may not be needed: if you installed the Interface to Win32 API you can use PlaySound to play your .wav file. This instruction is available both on the Base and Full version of CVI.
Alternatively you could directly interface to Windows Media Player via ActiveX: I have never tried but here there is the search result for "media player" on the CVI forum; you may find useful discussions in this list.
03-06-2017 09:05 AM
Hey, I tried one of the oldest Active X post from 2005, but it didn't work on my system.
maybe you have a demonstration for windows 10?
03-06-2017 10:03 AM
I haven't used ActiveX for that, but I have a sample program that makes use of PlaySound and works on Win10: you can find it here
