LabWindows/CVI
How to get measurement result report from CVI code created by NI Vision Assistant ?
I have a project to detect LED on PCB boards , So I study NI Vision Assistant example dental floss to measure Area (%), Mean Value,    Standard  Variation,    Minimal Value, Maximal Value. I can get the result (dental_floss_results.txt) by running batch processing. Please see the attached file dental_floss_results.txt. I created c code (labwindows 2012) in NI Vision Assistant, but I can’t get the same result from CVI. The main processing function is IVA_ProcessImage(Image *image), I don’t find the result like above parameters in this function. Could you help me for this issue? Or do you have any example to output result in CVI ? How to do to get these outputs?
Note : Dental.zip is CVI file.  dental floss.zip is image, dental_floss_result.txt is report from NI  Vision Assistant .
(2,143 Views)
UP
same probleme i have too
(1,964 Views)
