can you check that you still have a Statement step in your copy of TestStand - The application is looking for a match for "Statement" in the typeuseage list. - Go to the type palette in TestStand, and select NI_Types.ini. Check that Statement is one of the valid types.
Otherwise, try replacing "Statement" with any of the following :
StepType_Action - (Value: "Action")
StepType_CallExecutable - (Value: "CallExecutable")
StepType_Goto - (Value: "Goto")
StepType_Label - (Value: "Label")
StepType_LimitLoader - (Value: "LimitLoaderStep")
StepType_MessagePopup - (Value: "MessagePopup")
StepType_MultiNumericMeasurement - Value: "NI_MultipleNumericLimitTest")
StepType_NumericMeasurement - (Value: "NumericLimitTest")
StepType_PassFailTest - (
Value: "PassFailTest")
StepType_SequenceCall - (Value: "SequenceCall")
StepType_Statement - (Value: "Statement")
StepType_StringMeasurement - (Value: "StringValueTest")
If none of these work, then I'd suggest calling your local Ni tech support.
S.
// it takes almost no time to rate an answer
