LabWindows/CVI
How to delete table columns on 1-0 mask?
I have a 96-column table with strings. I also have 96-elemets int array (mask) with 1 and 0's.
What i want to do is to is to delete (or hide - but i've read that it's not possible) all the columns with index corresponding to 0 in mask array.
example:
table columns
1 2 3 4 5
mask
0 1 0 0 1
I want to delete columns 1, 3 and 4 and leave only 2 and 5 in my table.
How can i do that?
If i create for loop with i as index of the column, when i do DeleteTableColumns() columns count decreases, and i get an out-of range error:(
Or do i have a possibility to hide unneeded columns (not set their width to 1, it's very ugly-looking)?
Please help me(((
Message 1 of 9
(5,016 Views)
Accepted by topic author rovnyart
Hello rovnyart!
1. Removing table columns:
I suspect that the reason why you are getting the out-of-range error is due to the fact that in your for-loop, as you are deleting columns from the table, you'll eventually end up referencing a column that does no longer exist, because other columns before it have been deleted. While you are deleting each column at a time from your table in the for-loop, the column index number will shift, because you have deleted other columns before it.
In order to solve this, while you are deleting a column in your for-loop, make sure you also take into account that the column index is shifted because of removed columns.
2. Hiding table columns:
You can use the ATTR_COLUMN_VISIBLE attribute to hide table columns:
http://forums.ni.com/t5/LabWindows-CVI-Idea-Exchange/Add-ATTR-COLUMN-VISIBLE-attribute-for-table-col...
http://zone.ni.com/reference/en-XX/help/370051Y-01/cvi/uiref/cviattrcolumnvisible_column/
3. Alternatives:
Note that another alternative would also be to use a tree control instead, as the tree control also supports hidable columns:
http://forums.ni.com/t5/LabWindows-CVI/Table-Hide-Column/td-p/569773
Best regards!
- Johannes
Message 2 of 9
(5,010 Views)
Or more simpler start deleting columns from the end of the table Smiley Wink
Message 3 of 9
(5,006 Views)
That's not supported for tables, only for trees:(
Message 4 of 9
(4,990 Views)
...this depends on the version of CVI. For trees this attribute is available since version 7, for tables since version 2012.
Message 5 of 9
(4,987 Views)
And how should i do that?=)
Message 6 of 9
(4,985 Views)
for example having a loop index and a separate column index
Message 7 of 9
(4,978 Views)
thanks a lot, my friends!
I've updated to CVI 2012 and found, that ATTR_COLUMN_VISIBLE works on tables) Problem solved
Message 8 of 9
(4,974 Views)
You are very welcome, rovnyart! You should also give credits to
Message 9 of 9
(4,958 Views)
