LabWindows/CVI
How to compact and repair a MS Access database with NI CVI 8.5 (and SQL Toolkit)
Hello
I'm using the SQL Toolkit with CVI 8.5 for accessing MS Access Databases.
Is there a possibility to compact and repair the .mdb file with  CVI?
Thanks in advance.
Message 1 of 8
(4,864 Views)
please describe your question more in detail.
What do you mean with “compact and repair the .mdb file”.
Can’t you access the database? Do you get any error messages?
Please give me an overview of the scenario.
Regards.
Ulrich
AE NI-CER
Message 2 of 8
(4,831 Views)
Hello Ulrich,
with compact and repair I mean the MSAccess function "Compact and Repair".
Please follow the link below for more details:
http://office.microsoft.com/en-us/access-help/compact-and-repair-an-access-file-HP005187449.aspx
Normally you can execute this function directly in Access or with the Windows ODBC Data Sources Administrator  => "Control Panel" => "Administrative Tools" => "Data Sources (ODBC)"...
I want to execute this function via cvi code and not by hand ;-).
Thank you for your support.
Frank
Message 3 of 8
(4,823 Views)
Isn't there anyone who can help me Smiley Surprised?
Message 4 of 8
(4,764 Views)
This is probably of little help but in VB6 you can do this pragmatically from the DBEngine object as follows:
DBEngine.CompactDatabase <from name>, <to name>
more info here: http://support.microsoft.com/kb/158937
No idea what functionality is exposed through the tool kit. Worst case solution would be a VB6 DLL but not nice with the VB RTE...
Kevin
Message 5 of 8
(4,747 Views)
how to connect for data Base and to access to it
Message 6 of 8
(3,692 Views)
hello;
what about this error
NON-FATAL RUN-TIME ERROR: "loraRx.c", line 35, col 9, thread id 0x000011C0: Function DBConnect: (return value == -10 [0xfffffff6]). Native error code -2147467259 0x80004005 Microsoft OLE DB Provider for ODBC Drivers: [Microsoft][Gestionnaire de pilotes ODBC] Source de données introuvable et nom de pilote non spécifié??
please
Message 7 of 8
(3,691 Views)
Hello naima,
please stop hijacking old existing threads with new questions!
You posted added several messages to existing, several years old threads that had little or no relation at all with the argument of the thread itself: open a new thread instead giving all the informations that can help us to understand your problems.
In this case, useful infos can be the release of CVI and the toolkit you are using, which type of database are you trying to access and way of connection (e.g. connecting to a data source created in the ODBC administrator?).
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
Message 8 of 8
(3,676 Views)
