LabWindows/CVI
How to calc array length in Labwindows CVI ?
How to calc array length in Labwindows CVI ? In labwiew,I can find function to calc array length,but in CVI ,I can not ,...
(6,100 Views)
Hello 让一切随风,
Is your array dynamically allocated? If it's not, you can find the length like so:
int c[25];
int size_c = sizeof(c) / sizeof(int);
= Nelu F. || National Instruments.
(6,095 Views)
The solution you give can use in program preprcessing period, but in program run period,for example,array first address(Pointer) is known,how to calc  the length of array ? thanks ...
(6,087 Views)
Hello 让一切随风,
are you using Link list program?
(6,038 Views)
Hello 让一切随风
char  *name ;
int length = 0;
int i = 0;
 name = malloc(256) ;
strcpy(name   , "National Instruments");
while( name[i] ! = "\0")
  length ++;
i++
free(name);
(6,034 Views)
I want from C# to labwindows/cvi,i have some problem in the code,please help me correct wrong.thanks!
(4,302 Views)
