10-10-2013 01:22 AM
Hi All
I have a 3D image and i want to rotate its x,y and z axis, how it is possible kindly help me.
Umer
10-10-2013 01:47 PM
Hello Umer
When you say that you want to rotate the 3D graph, you mean programmatically? as you can rotate the 3D object using your mouse once the code is running.
To locate the examples in LabWindows/CVI that incorporate the 3D ActiveX Graph control, follow the steps below:
3DGraph.prj, 3DGraphAxis.prj, 3DGraphColorMap.prj, and 3DGraphContours.prj.RegardsMart G
