05-25-2017 04:14 AM
Just want to ask how to select "IGNORE" button programmatically when non-fatal error pop-up occurred. thanks.
Solved! Go to Solution.
05-25-2017 05:21 AM
You may check "ignore library Errors" for not displaying non fatal warnings messages from APIs being popped up.
05-25-2017 06:59 PM
Thanks. BTW, I am referring to the error pop-up when the program is running. The error says that some thread was being used by other thread, wait until finished.
I will try your recommendation. Would like also to ask if I implemented this action, is the "FATAL ERROR" message pop-up will be not shown as well? I am worrying that the "FATAL ERROR" or some other error will not be shown once I check the "ignore library errors". All I want is only the "Non Fatal Error" pop-up message.
Thanks again for your support.
05-29-2017 01:37 AM
This shall only affect the non fatal errors. The fatal error dialogues shall be still get popped up.
