Benchtop Measurement and Test
High-Performance Test
Systems Engineering Software
01-30-2014 10:35 AM
One possible alternative could be ti use FakeKeystroke command, but is sends command to the active panel. which means you must activate the other panel, issue the command and then return to the original panel, with possible effects on screen.
Thanks!
We'll be in touch soon!
