LabWindows/CVI
How send menu shortcut keystroke from child to parent panel
One possible alternative could be ti use FakeKeystroke command, but is sends command to the active panel. which means you must activate the other panel, issue the command and then return to the original panel, with possible effects on screen.
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
Message 11 of 11
(1,183 Views)
