There are a couple of examples that are included with CVI that demonstrate how to use CVI as an activex server. Open up help(F1), then under the Contents tab, go to Example Programs >> Communications >> ActiveX Examples >> Servers.
Also, under ..\Measurement Studio\CVI\bin folder, you will find a pdf called buildingactivexservers.pdf, which provides a detailed description of the activex servers created with CVI.
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
