I would like to be able to use Visual C++ code written by someone else in my LabWindows/CVI project. Is there some way I can use or 'import' the .cpp and it's associated .h files rather than rewriting the the code from C++ to C? I've seen the discussions about importing C++ dll's, (use extern "C"{ }) does this also apply to .cpp's?
Peggy
