You do not need the driver factory to use a DAQ board. The driver factory is for use with specific CVI drivers for other vendors instruments. A DAQ board will work best though the DAQ ActiveX control that gets installed with ComponentWorks. If you right click on the toolbox in VB and select Add... you will see many National instruments Controls. Add the DAQ ones (AI, AO, Digital, Counter, etc.). Then you can drop these on your form and use them directly with your board. They are much better and have an event driven interface for working with Data Acquisition.
Note: This all assumes you are using VB6, if you are using VB.NET you should get a newer Measurement Studio with Visual Studio .NET support.
Jeff
NI
