Srav,
The first thing that I would check is that you have a main function, this is something like this:
int main(int argc, char*argv[])
//Your code here
CVI will look for this function as a start point for you application. I've seen this same error when there is no main function. I may be totaly off track here, so let me know if this helps.
Juan Carlos
N.I.
