I am creating a driver for an XY plotter with a camera that is attached to a frame grabber. The basic driver functions are for XYZ movement and grabbing an image.
I am adding the ability to perform an alignment of a newly inserted object into the XY platform. I am using NI Vision to perform the color pattern matching and learn features. These alignment functions will be added to the instrument driver .fp file. I need the ability to check that the NI Vision software has been installed or run-time loaded so that I can then call the appropriate vision functions for creating a ROI, learning, and performing a color pattern match. If NI Vision has not been loaded then I need to inform the user that this function is not available an
d to contact NI to purchase NI Vision.
Is there a reliable way to determine if the NI Vision software or run-time has been installed on the computer?
