DSGetBountPlotID is a function that CVI uses when Datasocket binding option is enabled in a control. As you know this is a new feature in CVI 7.0. Just make sure that you don't use this in your UI at all.
the IVI_ATTR_IO_RESOURCE_DESCRIPTOR should recognized in the CVI 6.0, but if this is the only define that is not working you may want to copy the define for that constant to your code.
I hope this helps.
Juan Carlos
N.I.
