You can resize the font in a table by using the SetTableCellRangeAttribute. To resize the entire table, you can use for example
SetTableCellRangeAttribute (panel, control, VAL_TABLE_ENTIRE_RANGE, ATTR_TEXT_POINT_SIZE, size);
passing an integer to the
parameter.
This will change the font size but has no effect to the column and row width, which could need to be modified to make all text in the cells visible.
Hope this helps
Roberto
