Hello
CVI provides an activex interface that you can use to control it programatically. Check out the example under ..\CVI\samples\activex\cvi. The project uses a CVI Activex Automation Server instrument. I believe the function you need is CVI_AppAddFileToProject().
Bilal Durrani
NI
Bilal Durrani
NI
