I am compiling C-code using LabWindows/CVI for use as a shared library in LabVIEW on a PXI real-time target. In my C-code, I need to initialize some variables with a very small number to avoid divide by zero problems.
Is there a constant defined in one of the header files referenced by ansi_c.h that I can use? It is usually referred to as EPS, but that doesn't seem to be recognized by the compiler.
Thanks in advance,
Frenk
