Hello
I guess if you are concerned about speed issues, activex might be a bit slower than using a dll.
You could integrate just the Matlab functions into a C dll, and then just use the dll from CVI itself. If you are using Visual C++ to do it, make sure you specify extern "C" linkage, since CVI cannot handle name mangling.
Just a suggestion
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
