I think using CVI distribution kit, you can only specify things like
"root directory" which for most users would be "c:", unless for you user
it is "d:". Hard coding exact paths is difficult, I haven't found a way.
But your user can always change the folder if they want to install in a
different folder, during the setup.
vishi
SLRSLETE wrote:
> How can I specify the installation directory in a distribution kit? I
> need to specify a specific location on the 😧 drive. C: is my Windows
> and CVI drive.
> I am using CVI 7.0 and I need to be able to specify a specific path
> for the install location. This path is specified by my customer. I
> need to install on the 😧 drive. C: is my primary windows drive and
> CVI and IVI is not installed on the system.
The E: drive is the drive
> with the most space. I need to be able to specify a specific path.
