I belive that you can use the NIReport_SetTextAttribute(...) function to set the text to be centered right before you create the table this should center the rest of the table. Something like this:
NIReport_SetTextAttribute (reportHandle, NIR_TEXT_ATTR_ALIGNMENT, NIRConst_Center);
NIReport_TableStart (reportHandle, 4, 1);
NIReport_AppendText (reportHandle, CONF_SN_TEXT);
NIReport_TableNextCell (reportHandle);
There should be no need to wory about the pared size, the centered attribute should take care of that for you.
I hope this helps.
Juan Carlos
N.I.
