01-13-2014 04:46 PM
After performing an update on LabWindows/CVI 2010 (and geting an eval 2013 version) I had working versions of the conversion wizards in VS2010. Will these wizards stop working when the eval period is up or continue to work with my CVI 2010 version?
01-14-2014 08:25 AM
Hi dogsled45,
The conversion wizard that is attached to the unlicensed LabWindows/CVI 2013 will stop working at the end of the evaluation period, since you don't have a license for the software. If you have a license for LabWindows/CVI 2010 that will still work. Since they are both registered in VS2010, you might have to do a repair on the CVI 2010 install once CVI 2013 eval period is up.
01-23-2014 02:39 AM
When I converted the CVI 2010 project in VS2008, the IDE popped the dialog "Cannot find the VXIpnp Directory",How can i deal with that problem?
