NI Home
Cart Cart | Help
You are here:
Reply
SummerIntern
Accepted Solution
How can I convert a project from LabWindows/CVI 2010 to a Visual Studio 2011 project?
I have a good sized project, 12 source files, 14 headers, 1 uir, that I want to be able to edit and compile in MS Visual Studio 2011, MSVC++.
I remember being told that LabWindows dropped support for C++ in 2008 and no longer had a wizard for converting projects. I know I can go the DLL route, but I have never created a DLL before and wouldn't know where to begin with it. What would be the best way to go about this conversion?
Active Participant nyc
Re: How can I convert a project from LabWindows/CVI 2010 to a Visual Studio 2011 project?
There isn'a a Visual Studio 2011. There is a Visual Studio 2010 and a Visual Studio 2012 that is in beta.
SummerIntern
Well, I'm a little embarrassed. It's Visual Studio 2010.
Sorry.
There is, as far as I know, no automatic conversion tool.
Personally, I would convert to C#.
SummerIntern
How would I go about doing that?
manually
i.e. convert code to the .NET equivalent
SummerIntern
Okay. I'll look into that. Is that going to take care of the DAQmx libraries that I use, or am I going to have to import those libraries?
SummerIntern
Thanks nyc.
D_Biel
CVI 2010 still supports the Visual Studio Conversion Wizard for Visual Studio 2005/2008. We do plan to add support for VS 2010 in a future release.
If you need a VS 2010 project now, you can use the Visual Studio 2008 conversion wizard, then upgrade the VS 2008 project to VS 2010.
Product Support Engineer
