LabWindows/CVI
How can I convert a image such as ".bmp" to array
I want convert ".bmp" image file to array in Labwindows. How can I do that??
(3,494 Views)
Call GetBitmapFromFile then call AllocBitmapData to allocate buffers for the data (or you can call GetBitmapInfo and allocate them manually). Finally, call GetBitmapData. That will get you a color table and an array of indexes into it.
Ryan K.
(3,494 Views)
I have tried to use the method which you said.
But the converting result is so strange.
I want to convert bmp image to 8bit array .
Can I receive some example??
(3,494 Views)
There are different resolutions in a bitmap file, depending on the resolution is how you decode the information.
Here is an example that opens 24-bit images and calculates a histogram of each channel color (red, green, blue). You can use this example to read the data; there is an array with the data for each color.
I hope this helps.
Juan Carlos
N.I.
(3,494 Views)
The values of the array for an 8 bit pixmap are going to be indexes into the color table (which will contain 24 bit RGB colors). You can't process the values in the array directly (there is no 8-bit greyscale option). I'm not in front of a computer with CVI right now (travelling), but I think this example might show what you are looking for:
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3F0E356A4E034080020E74861&p_node=DZ52148&p_source=External
Ryan K.
(3,494 Views)
