I need to let users of my app sort things on-screen, just like one does in PowerPoint in the "slide sorter" view. The things to be sorted are essentially small paragraphs of text. (i.e. They must re-order the paragraphs, intact.)
Any advice on whether I should try to do this by putting the elements into PowerPoint via ActiveX and have them sort it there, or whether I should build my own panel and manage the sorting mechanics myself?
PowerPoint is quite flexible in terms of screen size, aspect ratio, resolution, etc. but provides users ample opportunity to mangle things or get lost in PowerPoint. Are there ways to lock it down via ActiveX to prevent editing of slides?
Conversely, if I build it myself, any advice on cleve
r ways to achieve the flexibility to accomodate various screen resolutions and aspect ratios? (e.g. on a wide screen, show 3 rows of 5 objects, but on a regular one show 4x4?) It all seems doable - just rather a lot of tedious programming, but with an end result that may be a bit inflexible, and perhaps kludgy-looking relative to the PowerPoint slide sorter.
Or has anyone already created such a sorter in CVI? If so, let's talk!
